disable tacacs-authorization
Description
Disables TACACS+ authorization.
Syntax Description
Default
N/A.
Usage Guidelines
This disables CLI command authorization but leaves user authentication enabled.
The following command disables TACACS+ CLI command authorization:
Platform Availability
